1958 420 Rear End Popping
Jaime W
08-21-2003 10:43:04
I have a 1958 420 that is "popping" in the rear end. The pop seems to originate from the outer right edge of the rear axle, close to the tire.
The pop "started" when I would make hard right turns. The pop is more prevalent now, occurring even when turning left.
My father-in-law thinks its a bearing. This sound like a good guess?
Also, assuming it is a bearing, what's the best way to take the wheel off? It "looks" like the wheel can just "spin" off (except for maybe the hub).
Thanks!
jw
Henry J
08-21-2003 15:59:46
 Re: 1958 420 Rear End Popping in reply to Jaime W, 08-21-2003 10:43:04
Jamie
I dont know all the 420 models, but do have a 420 in a million pieces. I ran across a popping noise, kinda sounds like someone knocking on the tranny case with a ball peen hammer when working my 420 like a dog with a front end loader. This was a W model. Someone told me to take off the cover just above where the pto attaches and shine a flashlight in there (jack up on wheel so the ring gear will turn) and look at the ring gear teeth. I did not want to know the answer lol. I took that cover off peeked in there and noticed some teeth broken off the ring gear. ohhhhh nasty nasty. If that is so, I would recommend replacing the ring and pinion only with a 435 since it has much more beef than a 420. If that is the case email me and i can give you a reference for the gears. Good luck!
buickanddeere
08-21-2003 21:30:05
 Re: Re: 1958 420 Rear End Popping in reply to Henry J, 08-21-2003 15:59:46
The cover to look in is the 1850 rpm pto outlet which is above the 540 rpm pto. The ring and pinion to use in slant dash and later 420's, 430's,435's and 440's is for the model 1010'selow serial number 31,000. Fits right in and is beefy.
RAY H.
08-21-2003 14:16:17
MY 430 DID THE SAME THING AS YOUR 420. BE PREPARED FOR A DIFFICULT JOB. YOU WILL NEED TO REMOVE THE FINAL DRIVE, THAT'S THE EASY PART. MINE WAS THE OUTER BEARING AND IT GAULDED THE AXEL TO THE POINT IT HAD TO BE WELDED UP AND THEN TURNED BACK TO BEARING SIZE. THE MOST DIFFICULT PART IS REMOVING THE BULL GEAR AS IT'S PRESSED ON THE AXEL. IT'S BEST LEFT TO SOMEONE THAT KNOWS WHAT THEY ARE DOING OR THEY WILL CRACK THE GEAR WHEN IT IS PRESSED OFF. NO AMOUNT OF HAMMERING WILL GET THE GEAR LOOSE. I TRIED! AFTER EVERYTHING IS REPAIRED IT NEEDS TO BE CHECKED, SO IT TURNS FREELY WITHOUT RUBBING ANYWHERE. IF IT RUBS, IT COULD BE IT ISN'T SET UP RIGHT, OR THE GEAR IS CRACKED AND GOES TOO FAR ON THE AXEL. GOOD LUCK! RAY
Ray
08-21-2003 12:42:02
Does it have spin out wheels? Probably just a loose wheel clamp letting the wheel rim slip.
Jaime W
08-21-2003 12:48:20
 Re: Re: 1958 420 Rear End Popping in reply to Ray, 08-21-2003 12:42:02
Well, first I'm not a mechanic (I program computers for a living :) ).
It does have "spin-out" wheels. I've tightened almost every bolt over there (I think), and it still pops. The way the wheel "appears" to work (AFAICT) is there are really large nuts that move a move away/torwards the tire itself. We've tightened those bolts pretty tight.
I'll tighten some more things up today when I get in this evening.
jw
Ray
08-21-2003 16:07:31
 Re: Re: Re: 1958 420 Rear End Popping in reply to Jaime W, 08-21-2003 12:48:20
I'm talking about the 4 clamps that hold the
center of the wheel to the rim,(on the 4 rails).
They can look and actually be tight and still
slip.You can usually make it slip buy holding the
opposite brake down while trying to move foreward
or backward. (that's when you usually here the pop.)
Clooney
08-21-2003 11:55:11
Jaime, it could be about anything from a final drive pinion, to a bad bearing, to a loose wheel.
~Start by checking the wheel for being loose, both the nuts & the center wheel nut.[loose wheels are probably the number one cause of a snapping sound in the wheel area]
~You didn't give a 420 type & there is some difference in the final drive areas between 420's so it's hard to give specifics....
