JD 40 Clutch Adjustment
Trevor
08-20-2003 19:59:33
i just bought this john deere 40 beautiful tractor did a head and valve job on it and ever since i got the tractor the clutch has been really touchy, there's enough free play but it seems to want to engage fully at one spot (it's hard to let the clutch out without it being jerky), the gut i bought it off of didn't have a manual and it's my first 2 cylinder so i'm not too familiar with then can anyone help me with this problem?
JB
08-21-2003 18:12:46
 Re: JD 40 Clutch Adjustment in reply to Trevor, 08-20-2003 19:59:33
Hi, my uncle had a M and neighbor had a 40 and we had a 420U and I drove them all a lot. The M and 40 always had a 'jumpy' clutch but the 420U was OK.
I was a difficult task with the M and 40 to inch a forage wagon backwards to the trough of a NH forage blower without crashing into the trough.
JB
Henry J
08-21-2003 16:03:13
Trevor
As Wayne says, you gotta pull it in half and replace the problem that you identify. Sorry for no good news cept you have the green lol. Good luck
Wayne in Tn.
08-21-2003 08:31:18
Trevor, The (touchy) clutch is a common problem on those models, especially if they have been sitting up a while. Usually the problem is glazing of the flywheel and clutch disc. and also the Pressure plate surface. If you can lock the brakes or get it against a tree or something and put it in high gear and try to slip the clutch might help it some. But likely you will have to break it into and replace the clutch disc and have the flywheel surfaced while you are at it.
