Old J.D. hydraulic cylinder
john
08-20-2003 19:59:08
I pulled an old JD Hydraulic cylinder out of my shed, it said 2 1/2 RC 1501 on it. It appears to be the same hydraulic cylinder that is shown in my 43 B manual. Can anyone tell me anything about it, is it worth fixing? I believe it was leaking when we put it in the shed, it was covered with oil so it isn't rusty. Thanks.
John
08-21-2003 19:42:34
 Re: Old J.D. hydraulic cylinder in reply to john, 08-20-2003 19:59:08
Thanks guys!!! I am going to keep it and fix it up. I set it up for one way operation today and will try it to see what it needs. The one part I know that it needs is the push pin that locks the attaching pins in (Had to drill one out), is it available or will I have to get one made?
DAOS bob
08-21-2003 20:41:16
 Re: Re: Old J.D. hydraulic cylinder in reply to John, 08-21-2003 19:42:34
The seals are avaiable from McMaster Carr of Chicago. I got some seals at a very reasonable cost from them. BUT what can be done with a pitted piston? Anyone rebuild the piston at a fair price?
darrell
08-21-2003 14:44:59
I just did my B cylinder. I got the seals and such fronm a local Deere dealer. They do not come as a kit any more. They ordered them piece by piece. The cost was a bit over $60.00
Dan
08-20-2003 20:56:54
Each of teh letter tractors had different cylinders, B, A, G, they all look about the same with the adjustable stop. I have one from an A I used on a mower for a number of years. It leaks down badly. I checked on seals and cups at JD, some are still available but spendy. You might find similar ones at a hydraulic supply. They are a good cylinder. If you want authenticity they are neat, if it is to use you can probably buy a new one for what it will cost you to repair it.
52BMAN
08-21-2003 13:16:22
 Re: Re: Old J.D. hydraulic cylinder in reply to Dan, 08-20-2003 20:56:54
Yes, the cylinder is for a JD B. It is worth something to the right person. I just bought new seals for $20.00 and fixed mine myself. They are not available from Deere any more. If you don't want to use it, I would be interested in buying it from you. Please let me know. Thanks very much,
Mark
Dan
08-21-2003 13:32:26
 Re: Re: Re: Old J.D. hydraulic cylinder in reply to 52BMAN, 08-21-2003 13:16:22
Where did you get your seals? Was it leaking oil out or just leaking down?
520-LP
08-21-2003 19:45:06
 Re: Re: Re: Re: Old J.D. hydraulic cylinder in reply to Dan, 08-21-2003 13:32:26
Dan years ago[like 30] I had a cylinder for a B that won't hold a #5 mower up I took the plunger out and cut a set of heavy leather washers like what a shoe shop would half sole a shoe with for it worked fine. they are still in it.
