Bad seal or just a bad boring question?
tom
08-20-2003 09:31:56
Hey Guys,
Posted this many ways, but never get an answer - last time. Have a 51 MT where I get can see there is always a slow drip of oil/fluid coming out of the PTO shaft area...question is what do I need to do to fix this? Do I need to pull the shaft and replace the seal? If so, how do you remove the shaft, etc? If not, please advise...
thanks one last time,
tom
ps - you guys have been great with all other question !
Tom, thank you very much
08-21-2003 05:03:52
 Re: Bad seal or just a bad boring question? in reply to tom, 08-20-2003 09:31:56
Thanks Fella's. I am assuming that I will drain the h-fluid prior to pulling the seal. I will also check for any grooves in the shaft...once this is done right, I am sure the ground below in the shed will be quite relieved...
John, the generator is coming along: new primary field coils too...the others insulation were burnt, cracked and the wiring didn't look too good...have the gas tank off now and steering assembly all apart, so when I get those repaired and back on, I can not wait to fire her up and see that Ammeter dial start moving for once...thanks again and I will keep you guys posted.
regards and many thanks,
tom
Wayne in Tn.
08-21-2003 08:36:03
 Re: Re: Bad seal or just a bad boring question? in reply to Tom, thank you very much , 08-21-2003 05:03:52
Tom, there is no need to drain the Hyd. fluid. It is not connected to the pto. The pto shaft gets its oil from the transmission oil. I have changed them without draining the trans. there will not be much oil there at the shaft. It is above the fill level and gets its oil by slinging action.
Lee
08-21-2003 02:23:00
Once you get in there it's possible that you may find a deep groove in the shaft causing even a new seal to leak in the same manner. If you'll consult better parts stores you can find what is called 'speedi sleeve' by CR (Chicago Rawhide) Seals. This is stainless steel sleeve that will drive down the shaft to where the seal lives and renew that particular area where the groove is. Not obligated to buy matching CR seal. Sorry I can't help with specific MT questions, I've never even seen one.
Dan
08-20-2003 13:39:18
According to my parts CD there is a seal on the rear, part number AM253T. Not sure how it is replaced.
Wayne in Tn.
08-20-2003 18:51:20
 Re: Re: Bad seal or just a bad boring question? in reply to Dan, 08-20-2003 13:39:18
That seal can be replaced from the rear (assuming it is like a 40, I don't have the book on an MT) If you don"t have a seal puller, the old one can be pried out with a screwdriver or cut out with a small chisel. Oil the new one and be gentle when driving it back in and drive it evenly all way around.
John T
08-20-2003 12:45:14
Hey there Tom, No, its not a boring question but I didn't hit on it cuz I'm not much into them M's except I have been helping you on the electrical stuff. Anyway, Im not sure how the M's are and I have none here or any parts book to look at, but if its like some other tractors I know of, they have a removeable exterior outer seal and cap/holder with like 3 small (1/4 or 5/16) bolts that hold it to the case on the outside, and once removed, you can easily replace the seal from its inside. Those type seals Im speaking of are pressed into the housings, from the inside of course.
If its not the exterior type seal holder, then you better talk to an M tractor man. Are there 3 lil bolts holdign a cap assembly right there on the outside which the PTO shaft runs through on your tractor????? ??
Regardless, once you get at the seal replacement (interior or exterior), I always clean and polish nice n round n smooth the shaft in the area of the seal and apply grease to the shaft and seal before replacement.
Lemme know, Good Luck n God Bless, hows the generator coming along by the way?????
