Mornin there Wolfie, Perhaps I can first answer your question on how to charge it, then I will explain the system to you. (A) ************* HOW TO CHARGE BATTERYS************* If you had a 24 volt charger, you could charge both at once in series with them still tied together, but I assume you have a 12 volt charger and want to charge each individually. On the tractor, the 24 volt charging system charges both at once in series at 24 volts. THEREFORE, charge one at a time using a 12 volt charger, and always (just like normal) connect the charger + to battery + and chargers - to batterys - (regardless which battery you are charging). If you charge right on the battery terminals (not use frame ground), theres less chance of any confusion. Then, you simply disconnect the charger (both terminals) from the battery just charged and go over and charge the other battery, + to + and - to -. Both batterys should be about equally charged and its best if both are similar rated and condition and state of charge. To answer your question, you dont have to charge both if both dont need it, but if only one is always down, you may have one bad or weaker battery (load test them both) or the 12 volt loads arent gettign shared between the 2 batteries as designed to via the switch and the A and B 12 volt circuits. The switch or wirign or a battery could be at fault, and be sure the center tie point to ground is connected properly. You might be sure the electrolyte is full in both batterys cells (above the plates), theres no gray or mily color in any cells, and maybe even have a shop load thest both of them if you doubt their condition. Make sure that where the 2 batteries are tied together at the center (see how it works section below) and that the center tie point of the 2 batteries is properly connected to the tractors frame. (B) *************** HOW IT WORKS********************* You have (2) 12 volt batteries connected in series which totals 24 volts, but the only things that run at 24 are the starter (has 2 terminals and both are isolated from ground) and the charging system. The batteries are connected in series with the + of one tied to the - of the other, and thats the center tie point which is also wired to the frame for frame ground. Then there remains 2 outermost untied battery posts, a + on one battery and a - on the other, which is 24 volts betwen those 2 outer posts. (Starter and charger 24 volt circuit) Those 24 volt + and - posts are the ones connected to the starter and charging system. Some 12 volts to feed lights etc are fed off one outermost battery post to ground (thats only 12 volts, between one batterys outermost untied post and frame ground remember) and the other 12 volt loads are fed off the opposite batterys outermost untied post to ground. Theres like two (A and B) battery circuits, each 12 volts between it and ground, fed to the switch. One of those batterys is positive grounded and the other negative grounded via that center tie point to ground as described above. I hope this helps you and post back or e mail [email protected] or call (812) 824-4608 if you have any more questions. Good Luck to ya and God Bless ya, let me know how you come out. John T Nordhoff in Indiana
