Hey there Dave, it could well be a carb or gas flow restriction problem, so to save time, (Its gettign real late here, sorry) I have cut n pasted the same carb and fuel flow test I posted below for you to troubleshoot. Then tomorrow, I can guide you through ignition troubleshooting more if its not a carb or flow problem. Since you say adjusting the needles dont help, the carb may have a restriction or the sediment bowl etc or the float level is off, but doing all my flow tests and postign back the results will sure help diagnose the problem maybe. COPY: HOWEVER, maybe we should look into a few other problems like fuel related or valves etc., so I have to ask a few questions to better diagnose a potential problem. I will talk about fuel or carb restrictions first in case shes starvign for fuel IS IT????
3) Does a bit of choking help her????
IF SO she may be runnign lean due to a fuel flow restriction or a carb problem, so do these tests and it will help us diagnose a fuel or carb problem maybe. 4) With the gas on if you open the carb bowls lower drain cock/plug, does a soild continuous stream of gas approx 1/16 inch in diameter flow out a couple minutes or so????? If not, theres insufficient gas keeping the bowl full and that can cause a lean condition. Such may be due to a restricted or clogged needle valve n seat or a flow restriction in the tank bottom or sediment bowl or side inlet carb fuel strainer. 5) If she dont pass that flow test, remove the line from the carbs inlet and see if a solid stream flows out the line the size of its inside diameter??? 6) If not, remove the glass sediment bowl and see if gas flows good out the lil top holes which fills the glass bowl??? 7) If not, there may be a restriction in the tanks bottom or the inlet pipe or any mesh screen etc. 8) If it has good flow through the line but the bottom bowl drain test I described above fails, the clog may be in the needle valve n seat or the side inlet strainer. 9) First, remove the lil side plug in the strainer and see if you can clean and carb cleaner it all out and get some cleaner down into the needle valve n seat and see if that helps??? If not, you can remove the strainers top nut and cap and try to clean out the strainer. 10) If the gas flow is good through the sediment bowl and line and strainer, but she still fails my bottom flow test, the needle valve n seat may be clogegd which you can get to and clean by removing the bowl. When in there, check the float and its level setting. 11) You might also check that the air cleaners lower bowl is clean and water free and theres no inlet air restrictions and the gas is clean and fresh and water free. 11) If the flow to the bowl is good (bottom flow tests passes) and she starves for fuel or needs choke to run better, the carbs main center vertical brass nozzle may be clogged, especially some of its lil teeny side holes. You may have to drill and tap its center to use a screw and nuts n washers to pull it out (DO NOT BEND OR PRY ITS TOP) and once out clean and polish and clean all its lil side holes. 12) Have you checked for vacuum leaks (leans out fuel mixture)??? Do that by spraying WD40 or crab claner or an unlit propane torch around the base of manifold and carb gaskets and throttle shaft bushings etc to see if that smooths thigns out. Thats usually more of an idle problem, however. If youre just having idle problems, post back and I will tell you how to troubleshoot that. 13) I havent addressed the quality of your spark, do BOTH plugs produce a good visible blue spark and NOT a faint thin wimpy yellow one??? If so, post back and I will guide you through more igntion troubleshooting tomorrow. Thats enough to keep you busy lol, so let us know how the spark looks,,,,, , and if shes leaning out or needs choke to smooth out,,,,, and the results of my flow tests. Post back or e mail [email protected] or call 812-824-4608 with any more questions and I will try my best to help you. God Bless Ya John T Nordhoff in Indiana
