1936 D long post but desperate
Farm w/Junk
08-19-2003 08:51:38
Hi I have a 1936 D that we had running great 2 months ago. We had Branson Ent. rebuild the magneto(Splitdorf 246T) and it worked great for a while but stopped clicking/snapping on impulse with the switch down. What would cause this? Then we took everything off except the magneto, so we could paint it. Now we went to start it after putting it togther and we cranked and cranked and not even a pop. We had better luck starting it after sitting for 15 years. So we got the truck and pulled it in high gear. When it started it was popping out through the air cleaner blowing oil out. It did this the first time we started it so we messed with the timing some but it should still be where we had it from before. Also what are the best carb settings? Would anything with the valves cause this? I really need help this is my first restoration and the oil specks all over me and the new paint dont look very good. Thanks to all.
Matt
Brokenwrench
08-19-2003 18:35:12
 Re: 1936 D long post but desperate in reply to Farm w/Junk, 08-19-2003 08:51:38
Sounds like the mag needs to go back and be rechecked. You should get a snap if the impulse is working correctly. Something has evidently gone wrong with the impulse and could have twisted something inside causing the timing to go haywire giving you the backfiring etc. The mag shop should guarantee their work for some period of time.
