MIKE HANLEY
08-19-2003 11:22:36
Re: 530 jumps out of 5th and 6th in reply to Gary, 08-19-2003 08:40:15
In the 40 years I have owen 2 bangers, I have never had to tear down transmission. I have had them pop out of gear but never had to go any further then the gearshift lever. There is a spring and washers on the end of the lever. When this becames weak when you shift you think you are in gear as the lever is all the way over in the slot. However with the weak spring, the ball on the end of the lever doesn't sit rigth to push the shifters over to sit right in the detents And again, you think it's fully in gear and it is not. Clooney and I totaly disagree on this. But I would check this out before I would tear down a transmission. This is so common, JD at one time sold a spring Kit for this quick repair. Grap the lever and if there is any up and down play in the lever, replace the spring and washers. To check proper ajustment. Bring down the lever from the left side to the slot that goes over to the rigth side. You will feel the dead of the nutrual just as you enter the crossover slot. Mark this with a pencel. Then go to the rigth side and bring the lever down as it enters the crossover slot till you hit the dead nutrual spot on that side. Mark that with a pencel. Messure from the outside of the box to the nearest pencel mark. They should be the same. If not it needs ajustment. Not saying you don't have more problems, but check the easy stuff first. In all my years, I have never seen a JD 2 cylinder transmission wear itself out. Every failer was caused by the operator. As years went by, the 2 bangers became the second or chore tractor and most no longer had ALL the oils changed when the book called for it. Add in some leaking gaskets so the oil is low plus not having the pulley brake properly ajusted so the gears grind shifting and well..... .Even if your tractor spends most of it's time in the shed,,unless it is climite controled,,Go by the book. If you get up in the morning and there is dew on your cars windshild, or if there are any foggy mornings, that same moisture is inside the castings of your JD. Even if it's sitting most of thev time in the shed, Change ALL fluids at least twice a year. You will be surprized how milky it will look and even if you never even used it much.
