Dubuque vs Waterloo
tom
08-18-2003 18:16:30
Hey Guys,
Besides becoming just self-absorbed in my JD MT, I wanted to learn more about the different types of tractors and their origins. Other than the cities they were made it, what are some of the [obvious] distinguishing differences between a Dubuque and Waterloo JD tractor? If there is a particular website or the equivalent that discusses these, your guidance would be immensely appreciated.
Thanks and hope I can someday return the favor.
regards,
tom
MIKE HANLEY
08-19-2003 06:39:05
 Re: Dubuque vs Waterloo in reply to tom, 08-18-2003 18:16:30
I think that because when JD wanted to enter the small tractor market (smaller then the "H") they started with the 62 (after experamenting with a garden size tractor) that revolved into the "L". Beening so small the 2 cylinder horisonal engine and the hand cluch was out. The L and the later "LA" had good sales and the mind set of the engineers working on those prodjects stayed with the 2 cylinder uprights and came up with the "M" During that time FORD was the leader in that size tractors with 9N with there 3 PT being the best feature on the FORD's. The "H" was already in that HP class but the "M" was equiped with the closest hitch possible without beening sued by FORD over a true 3 PT. You have to read all kinds of books and read between the lines and put two and two together to come up with the answer that the "M" was dezined to look and operate more like a FORD then the "M"'s bigger brothers. FORD only had one size tractor at a time from the 9N that became the 8N in 1948 and then became the NAA in 1953. it wasn't till 1956 till FORD came out with two tractors in there line at the same time, the 600 and the 800. But by that time everybody else had a small tractor in there line with a true 3 PT and in most cases, power streeing. FORD sales were down and they never did gain it's lead spot back in small tractors. By then JD's biggest competor was IH not only in the larger tractors but in the smaller tractors as well along with everybody else's small tractors.
Richard
08-19-2003 05:19:48
My take, is that the Waterloo tractors, or I should say the engineers were mind set from the origonal Waterloo Boy design, (two cylinder horizontal). The D, GP, and on to the A, G,H, and B models developed at Waterloo. When the Board looked into a garden sized tractor, Waterloo was too busy and the wagon works in Moline took on the project. This group of engineers didn't work under the same design principals and management at Waterloo. Hence the different verticle, and smaller design. During the war, the same people worked out and tested the model M, ( a response to the Ford N series, but influenced by the Allis B ). Deere built the Dubuque plant cause they had the forsight of demand after the war and knew all too well that the manufacturing capacity would have to be increased. Alot of the tooling and workers from Moline started production in Dubuque in 1947.
tom
08-19-2003 06:12:07
 Re: Re: Dubuque vs Waterloo in reply to Richard, 08-19-2003 05:19:48
Thanks Guys,
...your historical perspective Richard, combined with naming the models, where they were produced and why really lent to a much better understanding...thanks again.
JDVan
08-18-2003 23:41:29
The most obvious difference between the Dubuque tractors and the Waterloo tractos is quite straight forward. This is prior to 1960. Dubuque tractors had two cylinder vertical engines where as the Waterloo Tractors had two cylinder horizontal engines.
Pete/ME
08-19-2003 03:32:36
 Re: Re: Dubuque vs Waterloo in reply to JDVan, 08-18-2003 23:41:29
Is there some sort of reference book or history of John Deere manufacturing. I've got the usual coffee table books with the pretty pictures, and the two volume set that gives an outline of the tractors, but nowhere is there any discussion of Waterloo vs. Dubuque vs. Horizcon (sp?), their relationship and the reasons behind the separate operations.
