bryani289swmi, that regulator you bought isn't unusual. Most present day regulators are pretty universal so will fit about anything. ~The problem is, the terminals are probably now in a different location on the regulator than your original. ~Don't worry about it,, It will work. ~You B originally came with a 4 terminal voltage regulator [Bat], [Load], [Gen] & [Fld]. ~The new one may or may not have come with an [L] terminal [most now don't] ..... ..... ..... ..... .NOW FOR HOW TO WIRE IT???..... ..... ..... .... ~First identify the terminals mentioned above [if you only have 3 terminals without the [L] terminal don't worry, it will still work ~Once the terminals are identified,,, mount the regulator on the generator with a good clean mounting area & clean mounting screws [the regulator base MUST be grounded to the generator to function correctly],,, ~Then run a short 14 gage wire from the generators [F] post {smaller of the two} to the regulator's [Fld] terminal,,, ~Then run a 12 gage wire from the generator's [A] post {larger of the two} to the regulators [Gen] terminal, it could be under the regulator, or a pigtail wire running from under the regulator, or just a terminal sticking from the side of the regulator,,, ~Then run a 12 gage wire from the regulator's [Bat] terminal to the NON-BATTERY side of the ammeter [the original would be white],,, ~Then run a 14 gage wire from the light switch to the [L] terminal on the regulator [if you have an [L] terminal], if you don't have an [L] terminal just hook that wire to the [Bat] terminal on the regulator along with the wire from the ammeter [the original wire was black]. ~When it's all wired per above you will have to polarize the generator, to do that just make sure the battery is charged & installed, & the system is wired per above, then momentarily run a jumper wire from the regulators [Bat] terminal to the generator's [A] post. If you see a spark remove the jumper as it is then polarized..CAUTION: DO NOT touch that jumper to the generator's [F] post or regulator's [Fld] terminal or regulator damage is possible..... ..... ~On that condenser?.. some regulators have that capacitor option, it stops radio popping as the points open & close & also helps reduce the sparking across the regulator points. [email protected]
