4630 Blowby-How much is too much?
Paul Butler
08-18-2003 09:39:42
When I start my 73 4630 there is nothing at all out the crankcase vent. However after it is good and warm there is a fair amount of light white smoke.
Strange thing is I drove it home 2 hours at about 2200 RPM the whole way and it didn't burn hardly any oil at all.
Is this something I should worry about?
LLOYD
08-19-2003 16:42:41
 Re: 4630 Blowby-How much is too much? in reply to Paul Butler, 08-18-2003 09:39:42
My 4630 does the same thing and has less than 2000 hours on an engine rebuild. It does'nt do heavy duty anymore but I was concerned. It does'nt use oil and loses no coolant and has plenty of power. I have used it enough for a problem to show up if there was one.
G-MAN
08-18-2003 13:42:45
If the engine is not using much oil (every engine new or old HAS to consume at least a small amount of engine oil), you're probably dealing with normal blowby, particularly if the tractor runs well, starts well and has good power. Even a brand-new 8520 that is freshly broken in produces some amount of blowby, which is just what compression pressure that gets past the rings finding it's way out of the engine, and part of it is also oil vapor. That is what the tube is there for. How much there is depends on RPM, how much load is on the engine, and engine temperature. As the engine gets older and there is more wear, you'll have more blowby. Deere actually publishes specs and there is a procedure for checking blowby pressure with a manometer, but it is seldom if ever done. A good I wouldn't worry too much about moisture or antifreeze in the engine, especially if the oil on the dipstick looks normal and not milky. It's not too common for them to leak antifreeze into the oil, and if it were doing so, you'd be experiencing major issues with ruined rod and main bearings.
Britt Misker
08-18-2003 12:44:28
Paul,
Could it be water vapor that is comming out your breather? Does it quit smoking (steaming) after the tractor has been under load for a few hours? Does your coolant level in the radiator drop with no noticeable leaks? The point is, if it is not using an exceptional amount of oil, it could be moisture escaping through the breather. The moisture could be from condensation that occours while an engine sits and goes through the natural daily heating/cooling process. This will be most noticeable if the machine is left outside. Numerous starts without getting the oil up to full operating temperature will also cause moisture to collect in the crankcase. Storeing a machine in a shed or garage/barn really helps minimize this. If coolant is getting into the crankcase, then you have real problems, especially if you are using anit-freeze. This will eventually cause the engine to require a complete overhaul. Of course, your machine may be getting enough wear to start showing up as blow-by. If this is the case, the oil consumption will start to increase steadily.
I am not familiar with the 4360, but if there is a oil filler cap, or some other way of looking into the rocker cover, look to see if there is a build up of a milky white goo in there. If so, you probably have a coolant leak and need to do something about it ASAP.
Good Luck,
Britt
ET
08-18-2003 12:07:49
I wouldn't get to worried about it if it doesn't use much oil. When its getting realy bad with the engine idling there will be almost as much smoke coming out the breather as out the exaust pipie.
