1936 B clutch throwing oil
MDM
08-17-2003 21:54:20
Just made my maiden voyage, but clutch is throwing oil, out of the belt pulley. Did I miss something in assembly? Oil is being thrown out inside edge next to tractor.Please HELP, tractor is waaaaa aay to pretty to have oil spots all over it!!
Alicia
08-18-2003 17:58:48
 Re: 1936 B clutch throwing oil in reply to MDM, 08-17-2003 21:54:20
I don't know about the clutch but do you have any idea about how much a 1936 B john deer tractor would be worth? It hasn't been driven for a while but it did run and my father had it in a parade a few years ago. I am looking to sell it.
CKM
08-19-2003 08:45:43
 Re: Re: 1936 B clutch throwing oil in reply to Alicia, 08-18-2003 17:58:48
Alicia:Can not give you a honest value without seeing the tractor. Have seen tractors bring several hundred dollars to several thousand, just depends on the condition of tractor and what someone would give for it.
Clooney
08-18-2003 03:39:58
MDM, there isn't much to miss in there.
~Your �B� could be tossing oil out from behind the clutch pulley for a few different reasons; first� there is the possibility of an excess supply of oil to the 1st reduction cover area due to a worn [or misadjusted] R/H main bearing, or the bearing adjusting shims not being pushed all the way down tight to the crankshaft during adjustment so oil can then get by the shims, so then the operating sleeve flutes can't retain it all,,, or, the dust shield drain back hole is restricted or plugged,,, or, the 1st reduction cover to crankcase lower drain hole is plugged & allowing the oil level to remain too high,,, or, the pulley operating sleeve to pulley hub is worn & allowing the oil to run between the sleeve & pulley hub,,, or, you have combustion blow-by that is slightly pressurizing the crankcase & blowing oil out from behind the pulley,,, or, the oil you are using is too thin [try 40 weight oil in the engine],,, or, the engine oil pressure is set too high & forcing too much oil past the R/H main bearing,,, or, a combination of some of the above,,, or, something I forgot to mention here�
~If you installed new piston rings give them a little time to fully seat & seal before doing too much as maybe you just have some crankcase pressure due to non-seated rings. Then change to a straight weight 30 or 40 weight engine oil. ~If the oil pressure is too high [over] 10-15 psi hot at fast idle you might try setting it lower. If it still tosses a little oil [they all do a little] you will have to make a decision on if you want to pull the pulley area apart & see what you can find wrong.
[email protected]
MDM
08-18-2003 08:27:11
 Re: Re: 1936 B clutch throwing oil in reply to Clooney , 08-18-2003 03:39:58
Mr. Clooney: Thanks for your help, you helped me a couple times in the past. As a matter of fact, there are brand new rings in motor, only has run 3 hrs. stack is wet with oil, and smokes a fair amount. Oil pressure is ok, I will try 40 wt. oil to see if that helps. I'am getting alot of blow by through the crankcase vent stack. Has it been your experience that this common for a rebuilt motor with 10-40 oil? I will change to 40 wt. 1st and see what happens.
Clooney
08-18-2003 09:05:33
 Re: Re: Re: 1936 B clutch throwing oil in reply to MDM, 08-18-2003 08:27:11
MDM, I'm pretty sure that blow-by is causing your oil leakage at the pulley area [or at least contributing to it].
~Don't put the 40 weight oil in it yet! Wait until the rings break in some more. ~Probably be a good idea to install the cheapest 10 weight oil you can find, OR get some Deere break-in oil. I personally use the cheapest brand 10 weight oil I can find until the rings break in.
~The problem with those better quality 10W40 motor oils is, they have a real good anti-friction & anti-wear additive in them. That helps an engine live longer but is very detrimental to piston ring seating & break-in.
~Once you install the break-in type oil then put it to work [or on a dyno] for a while. You want to get those rings seated before the cylinders glaze over. ~Resist the urge to just idle it around & get a load on it to set those rings�..
