J D sickle mower pto shaft
Tim Chandler
08-17-2003 21:02:13
Howdy, Just rescued a JD seni mount mower with one trail wheel from the torch. Some say its a # 5 others say its a # 7. Any way I didnt get the tractor side of the pto shaft. Can I still get this part or is used the way to go. Thanks in advance Tim from the rockin TJC
Tim Chandler
08-18-2003 20:17:26
 Re: J D sickle mower pto shaft in reply to Tim Chandler, 08-17-2003 21:02:13
Thanks for the info. Ill check locally or maybe at Tractor supply in Gainesville Tx. Later Tim from Ok
ron in MN
08-18-2003 15:09:25
Just want to add a little to the good info from Mike and Dan. The splined PTO output shafts on tractors are not all the same diameter so be careful when getting these parts.
Dan
08-18-2003 06:59:34
I agree with Mike, we don't have a IH dealer here but have JD. They have a similar selection of parts. Just be sure to get the right shaft as some of those are not square but wider on one side.
MIKE HANLEY
08-17-2003 23:34:55
Our local CASE IH dealer has a bin as you walk in the door with all that is needed to make any PTO shaft. The shafts come in long lenghts and you cut off what you need. Just pick joint parts and do a little welding. I have seen the same parts at a chain farm supply store up in La Crosse. The safety shields won't be JD factory, but will work. I went to the IH dealer for PTO parts for our JD 31 post hole digger. (there were made by ARPS company and it is fast to walk in the door and get the parts as it is to have JD order it. Cheeper too as you only need to buy what you need.
