4020 diesel charging problem
John
08-17-2003 20:13:07
I have a 4020 Diesel 24 volt. The left battery will is not charging. I've put a new battery in thinking it was a bad battery and it still will not charge. What is the problem here. Is converting it to a 12 volt system the best solution? thanks
Curt M
08-20-2003 17:04:42
 Re: 4020 diesel charging problem in reply to John, 08-17-2003 20:13:07
I would suggest that if you are going to be inspecting all the wiring and taking the plate off, that you change the system to 12 volts. Deere has a nice kit to change it over. I changed my 4020 to 12 volts and I eliminated a lot of problems. good luck
Jailkeeper
08-18-2003 06:44:08
Make sure all the posts are clean and that the cables are in good shape. Especially the cross-over cable under the platform. If you haven't done so already, take the platform off so you can visually check all the cables and wiring. I know of several 4020s (ours included) that have burnt because of bad cross-over cables.
