36 B countershaft
loganeye
08-17-2003 18:59:19
I need help removing the countershaft. I have the
brakepully side bearing off, and the race from
the flywheel side is out. I can't get the shaft
out of the top, it binds the spider gear and the
front of the case, what am i missing?
Does anyone have a source for the roller assemblies LH and Rh JD7527R and JD7528R?
The local dealer shows one side availiable from
napa, the other one is unavailiable.
I appreciate any comments.
Ron Stephens
08-18-2003 05:08:40
 Re: 36 B countershaft in reply to loganeye, 08-17-2003 18:59:19
The bearing on the left side has to be removed. Then you can remove the first gear on the left. The rest will then come up through the top. Bearings should be available from JD.
loganeye
08-18-2003 06:41:42
 Re: Re: 36 B countershaft in reply to Ron Stephens, 08-18-2003 05:08:40
Thanks for the info on shaft removal.
My local dealer has been able to supply all of
the other bearings,except for these two. They were
not availiable from the obsolete wearhouse, he did
find a cross to a napa bearing, but for one side
only. Are there any further places to look?
thanks
Ron Stephens
08-18-2003 07:30:17
 Re: Re: Re: 36 B countershaft in reply to loganeye, 08-18-2003 06:41:42
Give Randy Rasmussen at 1-712-799-4293. I have had good luck having him find obsolete bearings.
