730D P/S
RickB
08-17-2003 07:35:08
I have a 730 pony start and have never been thrilled with the steering. Stumbled through much of the system and it is better, but the wheel is still 'heavy'. I know the response can be better. I am running HyGard in the system in it now. Is there something better I should be using? Also do the wire harnesses from the outfit in western NY fit and work like they should? Thanks in advance.
randy hall
08-17-2003 15:11:37
 Re: 730D P/S in reply to RickB, 08-17-2003 07:35:08
there is a subsitute, dextron two atf fluid. you will notice a difference in the ease of steering with this over hygard fluid. been using it in my 720 for over twenty years.
Hilltopper
08-17-2003 13:56:53
Mine on my "70" was never very good. After using it for 25 years that way I decided to fix it. When I tookthe flow contol apart I found the spring inside was broken up in there. It is a tapered spring and no longer available. I went to a hardware store and bought a similar one except for the taper. I had to put a washer on the adjusting screw to use a straight spring. It now has the best steering ever. My point be sure what is inside the system if it does not work properly.
JD70Jim
08-17-2003 12:17:36
You need JOHN DEERE AF2235R Power Steering Oil. It is the stuff the system was designed to use.
Clooney
08-17-2003 09:12:39
Rick, while the Deere P/S fluid is probably the best, it should still function just fine on HyGard for the short term.
~That Deere 2-cylinder steering system is quite complex if you aren't versed in it's hydraulic & mechanical function but is really very simple in design.
~There are more than a few things [or combination of things] that can cause the power steering to act like yours but the basic place to start is with an adjustment of the [flow control] valve..... To do that, first remove the cap nut then loosen the nut on the flow control valve screw, then turn the flow control adjusting screw in a little at a time & try it. If you get to a point where the front wheels begin to flutter, back it off a little. If you can turn it all the way in with no flutter & the steering doesn't get better you have a pump problem, or flow restriction, or a cam spring that's too tight, or an actuating sleeve with worn slots or pins, or improper worm end play, or a loose fork on the steering valve, or a combination of the above, or something I forgot to mention.
~The flow control valve screw is the one under the cap nut sticking out the front of the steering gear.
~It probably wouldn't hurt to MAKE SURE there is nothing binding in the steering system, including the lower spindle & any tie rod ends [wide front only].
~The next thing to do after a flow control adjustment is to do a vane by-pass test [it's in take book]. If you are getting a lot of oil by-passing the steering vanes you have probably found the problem & will have to overhaul the steering parts in the lower bolster..
~There is way too much typing to post the entire steering check out procedure here so do some of the above & post back with questions. You really should get the Deere power Steering manual as that will go step by step through the check-out procedure & will be a great help in tracking down your problem.
~That steering system isn't that complicated but you MUST understand how it works to get it working correctly. There really isn't a magic bullet that will make it work, it's usually a bunch of little things that make it fail...
Edward
08-17-2003 08:45:45
You need to use the John Deere power steering fluid! There is no substitute. Also check to see that the valves are moving freely in the housing.Do you get Two-Cylinder mag? Article in the Jan.-Feb. 2003 issue about Power Steering that may be of help to you. If you are a member of the Two-Cylinder club, they have a tech council that people can call with questions and help with the problems. Check their site Two-Cylinder.com for more good info!
