Good Morning Lynn, The 12 volts for the lights etc is supplied via the A and B 12 volt circuits which lead to the switches input. There should be one 12 volt circuit negative ground and another 12 volt circuit positive ground going to the switches input, does it have that now????? ??? The only places that are 24 volts are to the starter (2 big cables) and the generator/regulator. The two 12 volt batteries where joined at the middle tie point are connected to frame ground, which is why one of the batteries outermost untied terminals is + and the other remaining opposite outer untied post is -, thats the 24 volt source (2 outermost opposite battery untied terminals) while the two 12 volt sources are between frame ground (where the 2 batteies are joined together and grouned) and either outermost untied terminal (one + other -). So, make sure the tie point is wired to frame ground and make sure theres a wire (circuit A) to the switch from one outer untied + post and another (circuit B) from the opposite batteries outer untied - post. The only way you should read 24 on the switch would be if measured between the A and B input terminals, but between either of those terminals and frame, it would just be 12 volts. Then the switches output to the lights between it and ground is again just 12 volts. You might want to check the switch and its wirign again and the tie point ground to be sure theres 24 between A and B and 12 between either and ground. The lights receive one wire out of the switch (12 v to ground) and the other return is via the frame ground, but if you had the lights wired wrong with 2 wires (neither grounded) off the A and B circuits, that would give you 24 volts. When you say you have 24 at the lights, where are you measuring that from???? cuz there should be 1 wire to them which is 12 volts between it and frame ground. Again, only if you have the A and B circuits to the lights could you get 24 to them. Let us know, Good Luck n God Bless John T Nordhoff in Indiana
