1938 unstyled B
charlie
08-16-2003 19:59:46
Can anyone help with the right seat for unstyled's B's ? At the fair last night, mine has a heavy cast iron seat with CHAMPION on it and one has a thin "tin" seat that looked like a reproduction, but several fellows there said that the tin seat was the right one. Thank you
Lon
08-18-2003 14:08:59
 Re: 1938 unstyled B in reply to charlie, 08-16-2003 19:59:46
It's my understanding that the flatter 24 hole seat would be used on the short frame US B and the 9 hole pan seat on the long frame. That change happened at serial # 42200 in '37, so the '38 should have the 9-hole pan seat. The same thing happened on the US A at serial # 460000 in mid '37
Mark J
08-18-2003 10:15:29
It is my understanding that some time in 38 they they changed to the nine hole seat. When that was done, the angle on the seat channel on the portion of the seat channel that the seat attaches to was changed.
The early ones were parallel to the ground and the later ones were bent down a bit which pushed the operator into the seat. The 23 hole seat and the nine hole "sit" differantly.
You will have to look around a bit to see what I mean as if you are not looking for the change, you will probably not notice it.
Based on this, if you seat channel it not parallel to the ground but angles down a little, a nine hole seat would be proper.
Bman
08-16-2003 20:37:03
The nine hole john deere seat would be correct for the 38B
John T
08-16-2003 20:15:16
Hey Charlie, well, them fellows are right. The relatively small thin tin seat (with 24 holes I believe) is the correct one, even though the heavy cast one is more comfy and looks better. I dont believe Deere used any cast seats on any of those models and similar tractors ever.
Best Wishes, John T Nordhoff in Indiana
jdman(MO)
08-17-2003 05:30:56
 Re: Re: 1938 unstyled B in reply to John T, 08-16-2003 20:15:16
It would sure be nice to know the origin of the Champion Seats, for they have been around for at least 65 years and fit the John Deeres perfectly. Russ
