720 Hyd Leak
Rooster in Tenn
08-16-2003 19:21:40
My 720 is leaking at the bottom of the third arm. What can be making it leak? I can't see a seal or a "O" ring. Any help would helpful.
Edward
08-17-2003 09:03:29
 Re: 720 Hyd Leak in reply to Rooster in Tenn, 08-16-2003 19:21:40
If you are talking about where the top link is fastened, there is a seal on that shaft on the inside of the case and a bushing that is likely wore. The bushings are offered as a set only but if you remove the left bushing, there is a part number on it and the dealer can order it as that one is still available. This is not an easy thing to do but can be done with time and care. Best thing you could do is purchase a parts catalog and a repair manual from Deere. This will explain everything that you will need to do and the parts book gives a good break down to show how it goes together. Contact your local dealer and he can give you a toll free number to call and get the manuals you need.
