HELP ON JOHN DEERE 1955 Model 50 power steering!!!
Maureen
08-16-2003 15:07:35
Please help. We just picked up a restored 1955 model 50. The power steering seized up and will only turn one way. We replaced a broken bolt that holds the part that fits into a slot on the worm gear shaft and smoothed the areas it had gouged up in the cylinder (sorry, don't know what it's called...we're wingin' it). That didn't do it. Someone else told us that it could be a valve with O-rings in it somewhere in the power-steering...could the O-rings need cleaning or replacing? Also, can we run this tractor without the power steering? Any input would be appreciated.
ron in MN
08-16-2003 19:17:18
 Re: HELP ON JOHN DEERE 1955 Model 50 power steerin in reply to Maureen , 08-16-2003 15:07:35
Did you own this tractor before it was restored? If so, it should go back to whoever restored it and have them do the job right!
Hilltopper
08-16-2003 15:58:26
I will try to help you. My 720d did similar and after taking it all apart I found all it needed was an adjustment. Just ahead of the steering shaft there is a pipe plug in the worm gear housing. Take it out and inside the hole you will find a screw when you get it lined up by turning the shaft. Loosen the screw a little then turn the shaft counter clockwise to take up the slack.Retighten the screw. The book calls for staking the screw to keep it from moving on its own. Mine just happened all of a sudden. To much slack in there causes the steering valve to get out of adjustment Hope this helps.
Maureen
08-16-2003 18:19:49
 Re: Re: HELP ON JOHN DEERE 1955 Model 50 power ste in reply to Hilltopper, 08-16-2003 15:58:26
Thanks Hilltopper! I printed what you wrote and we will check it out tomorrow. I'll write another follow-up if we find the problem.
