Found source of water leak after two months on 44
David Lile
08-15-2003 18:32:20
Thanks for all the help. I had water pooling up in the push rod passages inside block. Most of you told me leak would be found in the old push rod sleeves in the head. I ran a test, I took head off then took water outlet off and made a plexiglas cover and sealed it off. I turned head over and filled with water. Sure enough water started slowly sipping out where push rod sleeve connects to head in the rear. Bought two new sleeves from John Deere pressed them in and flaired out at both ends to help seal. Eureka!! no more water in block.
