430 govenor
charles
08-15-2003 09:43:22
problem # 1, the govenor does not seem to function properly, however i have not put it under a load. #2, the throttle lever is hard to adjust, it seems to spring back to a mid podition after making a change/moving it. the throttle will not move to a idle posiion and stay there, it wants spring back to the mid position. same for increasing, it will not stay where you put it.need some advice please. thanks for any help.
Wayne in Tn.
08-15-2003 10:33:41
 Re: 430 govenor in reply to charles , 08-15-2003 09:43:22
Charles, the govenors on those models seldom give any trouble themselves, it is usually a carb. problem. Either sucking air at the throttle shaft, main nozzle clogged or float bad or incorrect setting. As to the throttle lever, there are a couple of friction discs in there behind a spring. These are available from your Deere dealer. Also the spring on the throttle linkage (near radiator) may be missing. This is a couple of things that cause the lever to not stay in position.
