Scott, you didn't tell us the year of your "B" so this will have to cover both designs.. ~If the big nut that holds it together is on the outside of the brake drum you can do the repair while the brake assembly is still on the tractor, if the nut is on the gear end you will have to pull the brake assemblies off the tractor.. ~If the nut is on the drum end just pull the nut off, then remove the lock washer & reinstall the nut so it is just slightly below the end of the shaft, then use a brass or lead hammer, brass drift & regular hammer, or piece of aluminum & hammer, then hit the end of the shaft to drive the shaft into the drum [CAUTION: don't drive on the nut or you risk wrecking the threads]..... .If the assembly is already removed from the tractor just remove the nut & lock washer, then reinstall the nut to just below the end of the shaft, then slam the assembly nut end down on a piece or plywood or hardwood to dislodge the drum or gear... If the drum won't come off you might have to back the adjuster off a little [that's the square ended stud sticking out the back of the brake assembly] Caution: that adjuster breaks easily so if it won't turn easily use heat & penetrating oil to free it] ~Once the drum [or gear] is removed, you can disassemble the brake assembly & free up & lube the sliding pin, adjusting pins, rollers & pins, pedal shaft, then check the return springs for being broken or stretched [a common problem].. When re-assembling use a good water proof high temp brake grease [available from your local auto parts store] on the pins, rollers, brake adjuster screw, sliding pin & spring end loops.. Use regular chassis grease on the pedal pivot to it's bore.. Some people use anti-seize but that is meant for non working joints & isn't the best for a working or sliding joint or pin.. ~Those brakes are as easy or easier than working on automotive brakes it's just the rust factor that can cause you problems.... ~If you want a parts breakdown of those brakes just give me an E-Mail & tell me what style & year "B" you are working on.. Put " B BRAKES" in the subject line of the E-Mail so I can find it in the maze of other E-Mails... ~Any questions just post back or E-Mail.... [email protected]
