HELP: Clutch Drive Disc on a 70 gas
Leeker
08-14-2003 21:44:37
Ok new basket case in the shop is a 1956 John Deere 70 gas with out power steering or live pto..... I am starting to wonder if I am going blind and that causes me to whip out my wallet at the first sign of green paint and the first note of an old 2-cyl running?
Anyhow, did some tweeking and slowly changed the coughing sputter to a smooth idle (as smooth as a Johnny can get) but then the problem arose, The clutch wouldn't grab, so while going to make a simple clutch adjustment I looked in the pulley only to realize that there was no drive disc in there. Someone must have started to rip this thing apart and hastly through it back together. I contacted the sellers and they have no idea, guy who was working on it passed away last fall. What is a good source for a new drive disc? Does deere stock something like that? Does anyone in the midwest have one they don't need? Is the drive disc in the clutch on a 70 gas different than the late G's or the 720-730 models? I assume gas/diesel wouldn't be an issue, but maybe I am wrong, since the 70 gas and 70 diesel have almost nothing in common save for decals. You tell me! Your the experts! I'm just the farmer
Leeker
JD60
08-15-2003 19:49:06
 Re: HELP: Clutch Drive Disc on a 70 gas in reply to Leeker, 08-14-2003 21:44:37
I got mine from Double D tractor somewhere in Ohio I think. Measure spline width for wear, because you might need one that is undersized. Good luck!
Moye
08-15-2003 19:09:54
Got one for a 70D from my Deere dealer last spring when I broke mine. Cost a pretty penny, but I got it the next day. Good luck. Moye
Jack
08-15-2003 06:12:20
I had broken mine so the only place I was able to find one was Dengler Tractor.They were proud of it but I had to have it.The 70 drive disc is different than a G.
Ellis
08-15-2003 04:30:28
There's one listed on this board for $105.
http://www.ytmag.com/cgi-bin/parts/model_parts.cgi?SearchArea=JD&&md=70
