Assuming you are running on straight gasoline in the large tank... Open the compression releases (petcocks) on the sides of the block. Roll top of flywheel forward a few turns to make sure the magneto "clicks" (the impulse tripping). Then turn the gas on (to select the large tank, with a normal 3-way valve, turn the lever pointing forward). Open the drain valve on the bottom of the carburetor and see if you get a steady stream of fuel for 30 seconds. If so, then shut the drain valve. Close the choke (downward, I THINK!, only until you get a nice mist of fuel out the petcocks) and rotate the flywheel counterclockwise. You will be able to notice the compression strokes by feel, and the fuel mist coming out the petcocks. No need to fight it, or spin fast, just roll it over on the compression stroke(s) over dead center. Hopefully it will fire and run. To shut the engine off, you have to turn the fuel off at the 3 way valve. It will take a minute to run out of fuel. Hopefully this helps. Clooney is the guy with D experience, and will correct me if I did something wrong. Is this John Deere more your style?
 Good luck! Brandon My Industrial John Deere website John Deere Diesels The LaGrange Engine Club
