3020 Diesel timing
Richard
08-14-2003 13:04:01
My 3020 diesel smokes black at idle with some slight detonations (a little similar to Harley motorbikes). These phenomena disappear above 1200 rpm. Tractor runs sharp no problem. Before checking the injectors for leaks I checked the timing, it is set right at TDC. Is this correct or is it too late which on one hand could explain the black smoke but on the other hand not the sharp running ?
jdemaris
08-14-2003 18:39:48
 Re: 3020 Diesel timing in reply to Richard, 08-14-2003 13:04:01
You are only checking the static timing it seems. You don't know what the tractor is doing when the engine is running. Sometimes things get a little out of whack and the fuel timing advances too much at low speed/idle. You need to remove the little metal trap door that covers the timing marks on the pump and put a plastic timing window on instead. Then you can check the fuel timing with the engine running. Once you know what is happening under running conditions, the fuel advance is adjustable with the engine running.
G-MAN
08-14-2003 13:48:44
The engine being timed at TDC is correct. The next easy thing to check would be the nozzles. I'd remove them and pop test them. Chances are you have one misfiring at lower speeds. If that's the case, get it fixed, as a drizzling or dripping nozzle can do serious engine damage in a hurry. You could also have some issues in the injection pump, but it's pretty simple to pull and test the nozzles.
