Coolant sending unit gauge
Russ C.
01-17-2004 15:26:21
Is there anyway to test a coolant sending unit and temperature gauage. The needle doesn't move.
old
01-17-2004 16:01:06
 Re: Coolant sending unit gauge in reply to Russ C., 01-17-2004 15:26:21
If its a non electic gauge you can put the sending unit in boiling water and see if it reads around 212 degrees if it electic you can put the sending unit in hot water and turn the switch on an see if it moves. If it doesn't it could be either one unless its the non electic and then its just plan bad
