Aftermarket bearings in 49A transmission
Jason-KY
08-14-2003 11:15:34
I have transmission apart in my A and need bearings can I get them aftermarket or should I get from J.D. dealer.Also should there be a gasket between cover and main case on right side ?Reason asking wasnt one when removed someone had been into it before and made a real mess.THANKS JASON
RK
08-15-2003 04:01:37
 Re: Aftermarket bearings in 49A transmission in reply to Jason-KY, 08-14-2003 11:15:34
I would suggest exactly the same as BL did below. Have dealt with them myself on behalf of my M, final drive bearings and seals, front axle bearings, and I'm about to order all of the transmission and differential bearings and seals. Good prices, friendly service, and original parts. Check it out...RK
henry j
08-14-2003 18:49:32
Jason
to my knowledge, JD did not make bearings. If you can find a manufacturer and number on the bearing you took out, you can go to your favorite parts store that is worth a hoot and get the same bearing and race at a substantial saving
B Lahmayer
08-14-2003 17:13:49
AW Bearing has proven to be a good online source of bearings for me. Here is the url: >Link
You>Link need the manufacturer part number on the bearing to order, not the JD part number. Auto stores can also often cross reference even from the JD part number but they typically charge about 25% more than AW Bearing in my area. I just replaced the axle bearings on a JD50 and could not get them through Deere. But so what, a Timken bearing is a Timken bearing no matter the part source. BL
JD-G
08-14-2003 14:05:10
Yes, there should be a gasket between the first gear reduction cover and the main case, which is the cover on the right side. I ordered my from Deere. I also got the timken bearings from Deere for the rear axles as well as the inner oil seals.
