2030 would like to know year of manufactor
stacy
01-17-2004 15:16:59
i have a 2030 john deere with tag on right side of block it has made in france. type number is 4219DL and series number is 91875-CD does anyone know what year it was manufactored
david val
01-17-2004 19:54:56
 Re: 2030 would like to know year of manufactor in reply to stacy, 01-17-2004 15:16:59
since the engine serial # end up with CD, which indicatets saran-france, the tractor is probably a mannhem tractor, in which case the serial # tag is on the right side of the front support just above the front axle, below the side screen.
there should be a serial # stamping in the cast next to it.
if it's covered by a loader frame or other hard to remove stuff, mayby a jd dealer can evaluate the seial # from the engine serial # (considering it's the original engine...).
david
buickanddeere
01-18-2004 05:51:25
 Re: Re: 2030 would like to know year of manufactor in reply to david val, 01-17-2004 19:54:56
The tractor serial number tag mounted on the right rail frame above the front axle. Will have "LO" as digits 1&2 if built in Mannheim. The engine serial number on the right side of block near the mechanical fuel pump will have "CD" as digits 1&2. Stands for Saran France JD engine works. Digits 4,5&6 are the displacement in cu". Transmission serial number near the right axle or on the cab crossmember will have digits 1&2 again as "LO" for Mannheim. Digits 6&7 are the transmission's max rated torque input.
MIKE HANLEY
01-17-2004 18:44:36
My book shows the the 2030 was made from 1972 to 1975, with the serial numbers endint with T or L. 1972 started with serial# 134 700T 1973 started with serial# 157 109T 1974 Started with serial# 140 000L or #187 301T 1975 started with serial# 145 500L or #213 350T
Production of the 2020 ended with the coming of the 2030 and the 2040 replaced the 2030 in 1976 starting with serial # 179 963. The 2030 that was tested at NEB for the offical tests on Nov 4th 1971 had a serial # of 06202611T, which doesn't match the serial numbers that are listed in the other book.
buickanddeere
01-17-2004 17:31:58
The 30 series ran from the 75 to 77 model year.
buickanddeere
01-18-2004 10:39:18
 Re: Re: 2030 would like to know year of manufactor in reply to buickanddeere, 01-17-2004 17:31:58
I was wrong, 72 to 75 model year. Had a seniors moment and used 75 as the start instead of the end date.
John
01-17-2004 15:58:40
Thats the engine serial number. Just above the trans hyd. dipstick should be the tractor serial number also. That would be at the rear of the right hand foot rest Bring a flashlight.
