730 Diesel wiring Questions
Deere Heaven
08-14-2003 06:42:10
I am finishing up on the electrical system on a 730 diesel, and I have a few questions. I cant seem to figure out where the battery cables connect to the starter? the schematic is not verry clear. Is there suppost to be a red light on the dash for the generator? Cant find anything on this in the schematic. One more thing on the rear light there are two wires. Why? Thanks, Brian Nielsen Austin, Tx.
F-I-T
08-14-2003 06:55:24
 Re: 730 Diesel wiring Questions in reply to Deere Heaven, 08-14-2003 06:42:10
Brian:
The wiring diagram is in the parts book. Send me an e-mail and maybe I can get you one. Others here might have better information than me, so be forewarned.
Yes, the parts book shows a red lamp for the generator for electric start tractors.
The rear light has two bulbs: a white work lamp and a red warning lamp.
Frank-in-Tallahassee
70D // 855
Deere Heaven
08-14-2003 09:55:38
 Re: Re: 730 Diesel wiring Questions in reply to F-I-T, 08-14-2003 06:55:24
I have a parts book, but I cant tell where they go. positve cable goes where bat, motor, witch terminal, and the same with the other. Thanks Brian, Nielsen
F-I-T
08-14-2003 10:06:22
 Re: Re: Re: 730 Diesel wiring Questions in reply to Deere Heaven, 08-14-2003 09:55:38
Brian:
Look closely at pages 40-42 and 40-43. Using the drawing and the parts breakdown it says that (12) battery cable, negative, to terminal on solenoid, and (11)cable, positive, to cranking motor.
HTH.
Frank
Clooney
08-14-2003 11:09:43
 Re: Re: Re: Re: 730 Diesel wiring Questions in reply to F-I-T, 08-14-2003 10:06:22
Brian/Frank, you have it correct...The cable running from the negative most battery post runs to the starter solenoid, the cable from the most positive battery post runs to the insulated stud on the side of the starter case.
Deere Heaven
08-14-2003 11:52:14
 Re: Re: Re: Re: Re: 730 Diesel wiring Questions in reply to Clooney , 08-14-2003 11:09:43
When you say insulated starter stud is this the stud comming straight out of the starter, by its self? Witch connection on the solenoid, what does it say? BAT, MOTOR, ??? Thanks for the help
