44..A...axle leaks
bob
08-13-2003 14:28:40
the big round metal disk that holds the felt retainer in the axle shaft....guess it holds the grease in?? it has moved out slightly....how do you get it back in??
Clooney
08-13-2003 17:59:06
 Re: 44..A...axle leaks in reply to bob, 08-13-2003 14:28:40
Bob, you should be able to use a block of wood & just lightly drive it back in. It is just a press fit.... If it came out because it is loose it probably won't stay without sealer on it. If it came out because that bearing was over greased, don't use so much grease the next time. If it came out because the axle shaft has too much end play because of a worn or loose bearing, nothing will hold it in until the axle problem is repaired...
