730 rear wheel adjustment ?
Deere Heaven
08-13-2003 07:17:17
I am wanting to take off the rear wheels to give em a fresh coat of life, but I have never worked on such a new machine. I am use to lots of penetrating oil, extra large puller and alot of elbow grease ( unstyled splined rear wheels .)How would I go about taking them off the axle? Thanks, Brian Nielsen Austin, TX.
Bob K
08-13-2003 08:09:42
 Re: 730 rear wheel adjustment ? in reply to Deere Heaven, 08-13-2003 07:17:17
Brian, run an archive search on wheel removal and check out the hits for any of the numbered series tractors (70, 720, 730, etc.).
In short, the hex-head shaft on the side of the hub contains a pinion gear that rolls the wheel in and out along the axle once the lug bolts have been loosened and the jack bolts have been tightened to press the tapered hubs apart.
