14T twine tension
green acres
08-13-2003 06:55:21
My 14T is tying great but the ropes are too loose and one is alot looser than the other. I have a book coming but I also have hay down and need to use it before it gets here. How do I tighten the tension on the line for tighter bales?
John
08-13-2003 17:28:58
 Re: 14T twine tension in reply to green acres, 08-13-2003 06:55:21
Tightning the twin adjustment cranks should automatically tighten up the twine. If your baler is packing more hay into one side of the bale than you will have uneven twine tension between the two. ( banana shaped bales) Chances are that the feeder forks which load the compression chamber are not in adjustment ( possibly worn drive chain) and are loading each charge of hay either two far or not far enough in the compression chamber. All those adjustments are based on an windrow size, baler rpm and travel speed, Not to mention consistency and variation in the types of crops.
HerbN
08-13-2003 09:56:20
John T. is totally right as I remember pulling that thing around the field. Here's one other thing. Quality of the twine. I can remember there was a big difference in stretch between brands. Some guys would tell you 5 out of 300 ain't bad. Hope you get it worked out.
John T
08-13-2003 08:05:37
Its been a while since I owned a 14T or 24T, but it sounds like you need to tighten the bale tensioners which are the 2 big screw downs on both outer sides of the rear discharge chute. Thats sets how tight the bales are and BOTH sides need to be set near the same to avoid lopsided bales. I always count the turns on each to keep em even, and try just a few turns at a time. If one side is looser, tighten it till they match. The bale length is set by that lever on the trip cam which trips the knotters to tie.
If shes tying fine leave her alone, but too tight bales may miss knots unless the knotters are adjusted accordingly. Thats the round twine disks which hold the string ends and the bill hook tension, but if shes working, DONT FIX IT LOL.
Sorry, its been a while since I square baled.
God Bless John T Nordhoff in Indiana
green acres
08-13-2003 09:47:49
 Re: Re: 14T twine tension in reply to John T, 08-13-2003 08:05:37
my bales ar tight enoug and even but my ropes seem way too loose. I can have one fall apart when putting them up. Someone suggested two bolts near the knotter that are for rope tension. I am going to check that. Baled 300 first cutting and lost maybe 5. Thanks for your help
PAINTS CORNER FARMS
07-05-2006 14:54:59
 Re: Re: Re: 14T twine tension in reply to green acres, 08-13-2003 09:47:49
hi john I am glad I saw this Iam having the same problem. my bales seem to be to loose.large enough but stinges are not tightening.which bolts on the knotter.are they adjustable like to the left less drag or right to tighten.where did you get the info I would sure like to read it so i DON"T END UP SHOOTING MY BALER.HEHEHE.THANKS.
