70 gas consumption
Leeker
08-13-2003 06:21:57
I can't find the horse power per hour per gallon rating on a 70 gas. I thought they included that in my little pocket data book, but I guess I was wrong.
Does anyone have those figures?
I expect it to be comparable to a "G" but I hope its a tad more efficient!
JD70Jim
08-13-2003 07:25:53
 Re: 70 gas consumption in reply to Leeker, 08-13-2003 06:21:57
The figures from Nebraska test 493 are:
TEST B, 100% max load test, 2 hours 4.498 gal/hr 10.74 hphr/gal 0.567 lb/hphr
TEST C, operating max load, 1 hr 3.845 gal/hr 11.92 hphr/gal 0.511 lb/hphr
Test H, operating drawbar load 10 hrs 3.255 gal/hr 10.33 hphr/gal 0.590 lb/hphr
Mike M
08-13-2003 06:58:21
I can give you a real world rating that I learned
twenty five or so years ago. You can work one on a double spring tooth working down ground all day long on a tank of gas if you leave it in the gear your uncle said to.{I
can't remember which gear though }But if you go back to the farthest away feild and gear up one gear to get done faster it still pulls it fine but it takes longer because you have to walk back
to get gas. This probablly won't help but I still
have to laugh at myself after all these years.
farmuse-real world
08-13-2003 09:36:36
 Re: Re: 70 gas consumption in reply to Mike M, 08-13-2003 06:58:21
70 Gas will burn full tank of fuel approximately 27 gallons in less than 8 hrs (approximately 10 acres) if you are pulling a 10ft double cut disk in fourth gear.But when they were built gas only cost around 20 cents a gallon. Listen to it cluck and forget about fuel consumption!!!!!
