Use of Gasket Material.......Clooney??
AWB
08-13-2003 05:18:50
I have a tractor that I am restoring and cannot find a gasket. The surface is on the surface between the transmission and the rest of the frame. The repair must be tight to avoid oil leaks. Is this a suitable application for some of the comercially available form a gasket type compounds? Any help would be greatly appreciated. Thanks.
Clooney
08-13-2003 06:49:28
 Re: Use of Gasket Material.......Clooney?? in reply to AWB, 08-13-2003 05:18:50
AWB, yes, there are some real good gasket substitutes on the market as well as the option of making a gasket from sheet gasket material.
~Give me the tractor make & model & the exact usage point. On the old Deere's, in lot of cases the gaskets are also shims & the thickness must be kept the same or at least controlled.
