Help with Fairbanks-Morse DRV2B Magneto
Leon
08-12-2003 22:54:45
I just got the above mentioned mag, and it has spark, but it is very weak. Any ideas on what needs to be done to get it back to functional condition? TIA Leon
Clooney
08-13-2003 03:57:47
 Re: Help with Fairbanks-Morse DRV2B Magneto in reply to Leon, 08-12-2003 22:54:45
Leon, I know very little about the DRV 2B & can only tell you what I have found wrong with the few I have messed with over the years. There are little spring brushes in holders that attach to the distributor cap [where the plug wires go in] & I have found those burned, damaged, & frozen up, and the rotor [interrupter] tends to oxidize causing a poor energy transfer, also the bearings get worn & cause the points to not function correctly. ~If you take yours apart be sure to mark everything internally on removal so you don't have to re-time it when done. ~On the few I have worked on, I have installed a coil on one due to it's failure, & found stuck brushes on a couple others.
~The magnet does tend to degrade on those DRV2B mags so IF YOU EVER pull it apart so the magnet has no keeper across it, it will loose it's magnetism almost immediately so then you are probably looking at a magnet recharge at the least.
~A weak magnet is a major cause of low spark output on those old external magnet magnetos.
~Start with a cleaning of the points as oxidized points is the leading cause of a mag not producing a good spark, then clean the interrupter disk of oxidation & discolor, then make sure the brushes are free in their holders. If you took the mag apart make sure it is internally timed correctly as the points must open at peak voltage production for a good spark. Then if still no good spark have the magnet re-magnetized [if you go to a major show like Portland take it with you as there are mag vendors like "Mark�s" that will magnetize it for you on the spot].
~If still not a good spark, suspect the internal coil or an open or shorted condenser.
