Clooney, generator off 60, found problem
Don c
08-12-2003 11:10:55
Took generator back to person who repaired it, checked out good again. put back on and didn't charge. pulled dash and found where we wired it wrong,we even had your diagram you sent. generator wire and starter wire both on same terminal and the switch wire on the other terminal by it self, Dumb, changed around and charges great now. thanks for all the help as its running good now. Don c
Clooney
08-12-2003 18:32:23
 Re: Clooney, generator off 60, found problem in reply to Don c, 08-12-2003 11:10:55
Don, that's a common problem & you aren't the first to encounter it.
~Problem is it will show a discharge but not a charge. ~It was still charging the way you had it, it just didn't show it on the ammeter..
