FIT and others
tom
08-12-2003 06:56:11
How is the best way to prep/clean the interior tank before applying the coating material? I have heard power-washing, but is there a special type nozzle to get into the bottom hole and access the whole interior of the tank?
When cleaning and coating the inside of the gas tank, what do you guys use to plug the bottom hole of the gas tank where the fuel filter screws in? I guess you do not want to coat the grooves because when screwing the filter back it, would it make it too tight and or loosen the lining material and have this debris in the tank, fuel line, etc...
If there are any tricks to the trade, it would be greatly appreciated...like to do this only once right the first time.
Thanks in advance for you help,
tom
F-I-T
08-12-2003 08:53:14
 Re: FIT and others in reply to tom, 08-12-2003 06:56:11
Tom:
I use a power washer that has a variable width nozzle, so I can use a straight stream, or a fan. Some people have rotary nozzles that they claim really do a much better job of cleaning. I might get one of those someday. Just spend a lot of time moving the nozzles around in a rotating cone inside the tank. You'll get most everything of any size. The coating process will stick tight any thing that is left loose anyway. I generally blast through any hole that is available, and if I can't get to most areas, I use a half can of lye per 5 gallons water, mix it up in the tank, cork or plug the bottom bung and let it sit level and completely full (this soaks the top inside surface, too) for a couple of days, THEN powerwash again. Then swish with phosphoric acid which will etch and de-rust the tank, THEN powerwash again. Tossing a short length of chain in the tank and shaking it around will help know any flakes of crud and rust loose. THEN powerwash again.
To plug the bottom hole, I think I'd use a brass pipe plug. They tend to go in farther. I have already used a cork that fit well, but as you say, it really dones't fill the threads adequately.
Frank-in-Tallahassee
70D // 855
