JD 2640 LOADER
FRANK ( TEX. )
08-11-2003 21:37:03
LOOKING TO BUY LOADER FOR 1982 JOHN DEERE 2640, BUT WITCH MODEL WOULD BE A GOOD HEAVY DUTY LOADER OR IS BEST SUITED FOR THIS MODEL
Brokenwrench
08-12-2003 16:57:31
 Re: JD 2640 LOADER in reply to FRANK ( TEX. ), 08-11-2003 21:37:03
A JD 48,or 148 is the correct JD loader for that tractor (in a used loader).Make sure you get the proper utility tractor mounts.You should be able to pick one of these up for around $3000 with a valve. There are numerous aftermarket manufacturers also. If you don't use a Deere loader,make sure whatever loader you use has a good subframe that mounts to the tractor.Make sure the loader has a CLOSED center valve if you require it. I've had a few through the shop that have broken the bellhousings because they just bolted to the bell housing and the front of the tractor with no sub frame like the Deere loaders have incorporated in the mounts.
John
08-12-2003 00:04:08
Theres a lot of loaders that will fit all depending on what brackets that can be found or fabricated. Thats assuming you looking for a used loader thats as old as your tractor. Probably a rear axle mount would be the most rugged. Maybe find some 2640 Deere literature and see what was recommended when your 2640 was new. And thats assumming you want to keep it all Deere.
cannonball
08-12-2003 04:55:10
 Re: Re: JD 2640 LOADER in reply to John, 08-12-2003 00:04:08
jd 146.....
