47 B Clutch and Flywheel Questions
IA Bob
08-11-2003 20:19:23
I am new to JD's and have a 47 B. I am trying to track down a "clunk" that comes from the clutch area. I have read posts about the possibility of a loose flywheel and my question is - how does the novice figure out if the flywheel is loose?
Second, I have started to take the clutch apart, but have not pulled the clutch drive yet. The gear on the drive sets out about 1/4 inch from the end of the cam shaft which sounds normal from other posts I have read - right? There is one old broken tooth on the drive gear and when I pulled the outer clutch plates off, a newly broken tooth fell off the drive gear, so there are now two broken teeth. What would cause these broken teeth? Should I replace the clutch drive, or is there another problem I need to fix first? Thanks for all your help as usual!!
Clooney
08-12-2003 03:51:58
 Re: 47 B Clutch and Flywheel Questions in reply to IA Bob, 08-11-2003 20:19:23
Bob, look at the flywheel to crankshaft for signs of movement, look for any metal dust, look for excess crankshaft end play. Then put a wrench on the flywheel bolts & make sure they aren't loose.
~On that clutch driver...I presume you mean "The gear on the drive sets out about 1/4 inch from the end of the CRANKSHAFT ~" & not [camshaft] correct?
~That would be about normal.
~Those broken teeth could be caused by worn clutch plates riding on the ends of the driver teeth, or, someone using a gear puller on that drive disk at one time, or, metal fatigue, or,?..You really should replace it..
IA Bob
08-12-2003 06:13:20
 Re: Re: 47 B Clutch and Flywheel Questions in reply to Clooney , 08-12-2003 03:51:58
Thanks Clooney, and yes I meant Crankshaft! Another question I have is, how to know that the fiber clutch disks need replacing. Mine are pretty well glazed, with a glass like surface - I assume this means it is time for replacement?
