Broke ANOTHER clutch bolt - Clooney, others help!
RayP(MI)
08-11-2003 19:40:27
I'm the guy who broke the clutch adjusting bolt on a '49 JD B couple weeks back, while bailing hay. Had trouble getting clutch apart and posted questions about that. Was bailing hay again yesterday and broke a second bolt. Am I doing something wrong? Thought I had all three bolts adjusted pretty much the same: Tightened all to the same torque with a torque wrench, then backed all three off the same number of turns, until the clutch seemed to operate properly, as far as engaging and releasing. Worked fine for a couple weeks, then second bolt broke. Am I doing something wrong, or just unlucky? Metal fatigue? Is driving the baler too hard on the clutch? First baler was a Oliver 60-T, this time a 268 Hayliner. Hayliner seemed easier on the tractor.
Clooney
08-12-2003 03:58:30
 Re: Broke ANOTHER clutch bolt - Clooney, others he in reply to RayP(MI), 08-11-2003 19:40:27
Ray, I really don't know what is happening there. I would guess the bolts are just old & brittle.
~Where are the bolts breaking? If about the point that they exit the pulley holes maybe they are just worn from riding on the ends of the pulley holes & that is the fracture point. Remember, those bolts take a lot of the clutch drive load while it's working.
~You might want to install 3 new adjusting bolts & see if that cures the problem. Not cheap but that way you will know...
RayP(MI)
08-12-2003 04:21:54
 Re: Re: Broke ANOTHER clutch bolt - Clooney, other in reply to Clooney , 08-12-2003 03:58:30
Clooney, Bolts are breaking on threaded portion, just below where the bolt steps down for the threads. And before the area where the nut is.
Farmer Jack
08-13-2003 09:50:10
 Re: Re: Re: Broke ANOTHER clutch bolt - Clooney, o in reply to RayP(MI), 08-12-2003 04:21:54
Ray, are the bolts necked (smaller diameter) in the area of the failure? An OT once told me to adjust the clutch tightens (with a socket wrench) all three nuts and then backs them off equal turns on all three (simultaneously) until the clutch can be disengage with the amount of force stated in the manual.
