Cant get R to run
JD R
08-11-2003 14:54:57
I just got an R this weekend and am having trouble getting it to run. The pony started but i can't get the diesel to fire but just for a few seconds and poorly when it does run. I have checked the fuel system and bleed it just to make sure there was no air in the line. I also pulled the injecters out and watched the fuel spray and it looks good there. I took the air cleaner off just to make sure it wasnt blocked but it still hasn't helped. I can get it to take off with either but will still not run very long. Is there anything anyone can suggest doing. I bought the tractor sight unseen and it was supposed to be running so other than that i dont know much about it. The trucker that hauled it in said they ran it onto the trailer but didnt take note to how well it was running. Thanks for any advise.
Austin Barker
08-15-2003 20:58:05
 Re: Cant get R to run in reply to JD R, 08-11-2003 14:54:57
You might want to check the compression on that because if it has poor compression then diesels do not like to run well if at all. a way to fix this would be to maybe put new rings in it.
Austin
