1944 John Deere Head Gasket
David Lile
08-10-2003 21:03:07
What if anything is good to put on a new head gasket to make a good seal?
Clooney
08-11-2003 03:20:57
 Re: 1944 John Deere Head Gasket in reply to David Lile, 08-10-2003 21:03:07
David, it depends on the head gasket type. There are a lot of different opinions on what works good on those head gaskets & it ranges from the spray Hi-Tac or copper coats , to oil, to Permatex, to grease.
Personally I use a light coating of Permatex #3 on both sides, [not on the steel fire rings surrounding the cylinders though], with extremely good luck.
~Using any type of good quality sealant on the gasket is a good way to prevent water seeps but does mandate a head re-torque after a few heating & cooling cycles.
