41 B Fine tuning
Matt
08-10-2003 18:01:26
Well after 2 long years, I have my tractor about 99% done. She is running beautiful. I don't ever remember the hand start starting so easy. I just have two minor things that I dont know how to fix yet.
1. The right wheel is moving back and forth. My tractor actually has the cast wheels with the ears that are all one piece. Well in the process of taking the wheels off, one broke. Then I found out my Dad did the same thing abour 10 years ago, so all three ears were broken. I went to a junk yard and tried to find a similar replacement, but found out how hard they are to locate. So I found a new one with the split rim and cast where the ears bolt through the cast. But for some reason no matter how hard I tighten the bolts through the coller and cast center, it keeps moving. Does anyone have and suggestions on how to keep this from moving.
2. The belt pulley seems like it is getting hot. Is this normal, or is it supposed to stay cool?
Thanks for all the advice I have gotten over the last 2 years. This board has been a wealth of knowledge and encourgage ment. I get to be in my first big show in 3 days. I can't wait.
Matt
Clooney
08-11-2003 04:07:26
 Re: 41 B Fine tuning in reply to Matt, 08-10-2003 18:01:26
Matt, 1). The right wheel is moving back and forth..... You can probably tighten that wheel hub up by installing a band of tin [maybe .020"-.030" thick between the hub clamp & hub. That tin band should force the hub to hold on the axle. If done neatly with the excess tin trimmed off it won't be noticeable under the clamp.
2). The belt pulley seems like it is getting hot..... Depends on how hot? If real hot & only a short run time suspect the clutch is slipping. If it just gets moderately hot on long run times that is normal...
