Generator squeal
Navy Chief
08-10-2003 08:44:58
Hey all, I am in the process of repainting my Grandfather's 1952 "A" Ser# 702697. I removed the generator, and when rotating it by hand, the rear bushing squeals. I removed the back cover, gently disconected the brushes, and examined the bushing. Visually it loks ok, and the rotor shaft looks fine as well. I cleaned the parts, lubed them with a thin coat of hi temp grease, reassembled and still the same squeal. Any advice?
Respectfully
Eric
Clooney
08-10-2003 18:46:45
 Re: Generator squeal in reply to Navy Chief, 08-10-2003 08:44:58
Eric, that generator brush squeal is normal on a generator that has some run time on it. Especially if the armature is turned backwards. ~Even some alternators make that noise. ~As long as it doesn't squeal while running on the tractor don't worry about it. ~Cleaning the commutator & replacing the brushes will eliminate it for a while but it will just come back as soon as the brushes wear back in...
Jake
08-10-2003 09:33:22
It is probably the brushes squealing from rubbing on the commutator. That is common.
To verify, just lift the brushes up a bit then try it. It probably will not squeal at operating speed.
That rear bushing uses oil, usually there is a little oil cup thing (if not broken or missing)and a felt wick to hold some oil in the reservior.
Navy Chief
08-10-2003 10:04:42
 Re: Re: Generator squeal in reply to Jake, 08-10-2003 09:33:22
Hey Jake, Went out to the garage, and reinstalled the back section of the generator. Pulled the brushes away, and no more squeal. Brushes snap back into place, and the noise returns. I have not operated this tractor in several years. Is it time for new brushes, or what is the correct cure?
Respectfully
Eric
Bob
08-10-2003 13:38:02
 Re: Re: Re: Generator squeal in reply to Navy Chief, 08-10-2003 10:04:42
Does it squeal when running on the tractor, or when you turn it by hand? If it is only squealing when turned by hand, no corrective action is needed.
John T
08-10-2003 10:27:03
If the commutator is not clean, smooth and concentric and/or if the spacer insulator bars between the segments is not undercut so its below the copper, the brushes can bounce and chatter. You might get by with a cleaning/polishing of the commutator and sanding the brush ends assuming the brushes arent worn down and are too short (if so they need replaced). If they had been removed and got put in backwards they could chatter, cuz they would have their wear in angles just bass ackwards from the rotation direction they wore in to. If theres any of the hold down assembly or springs or wires etc rubbing the commutator versus the carbon brushes as intended, it can cause a squeal. Just examine the brushes and commutator and hold down springs etc for interference with teh commutator and make sure no brushes got reversed and the fix may be simple.
John T Nordhoff in Indiana
Jake
08-10-2003 11:30:02
 Re: Re: Re: Re: Generator squeal in reply to John T, 08-10-2003 10:27:03
A glazed commutator and/or brushes will cause squeal. Use some sand paper (NOT emery cloth, it has conductive particles that will short out things) and clean the commutator and brush ends.
You do NOT want a mirror finish, that will glaze and squeal in short order.
