Hey Tom, are you Tom S who called me last week and we e mailed a lot (my e mail has been down but back up now sorry) or another Tom????? ?? Is this on that M ????? If so feel free to call again, too much typing gets confusing (812) 824-4608 1) Anyway, you say the ammeter is good and shows battery voltage on both sides (which is what it should show), so is one of the wires off of it a wire down to that cut out relay????? Is the wire on the non generator side of the relay always hot????? it should be and needs to be so the generator can charge the battery. When the gens voltage rises higher than the batterys, that relay clsoes you know, and opens otherwise (like tractor off) so the battery dont reverse discharge through the generator. Is the relay grounded????? ????? ??? 2) If theres battery voltage to the relay (non generator side) at WOT if you jump a wire around the relay (connect in and out together) that by passes the relay (same as it makes up closign its contacts) and if the gen is putting out, the ammeter should show charge if its wired right and all else is good. If you turn the lights on not runnign, does the ammeter swing to discharge???? it should. Some relays are bi polar and work pos or neg ground via a wire reversal, others only work at pos or neg grnd only. Is your relay wired right and grounded????? ??? does it have like + and - terminals or BAT and ARM (or GEN) terminals???? If its wiresd in reverse, it wont work!!!!! !!!!! !!! Regardless, if its by passed and the gen is puttign out, she should show charge. 3) At WOT and the relay by passed if she dont charge, if you ground out the field post on the gen will she charge then??? If that makes her charge, the field control light switch or a wire up to it may be bad or the switch isnt well grounded. 4) If the gen and relay is well grounded,,,,, ,,,, and the relay by passed,,,,, ,,,, and it has voltage to its non gen terminal,,,,, ,,, and the Field post on the gen is grounded out,,,,, ,, and she dotn charge,,,,, , the gen is likely bad. 5) You can motor test the gen by removign its belt and applying battery power to its ARM post and it should turn. If it does turn and then you ground out the field post, it should slow down slightly. If it passes both those tests, its usually fine. If not, its probably bad. 6) Often the gens brush hold down springs are bad or stuck or corrodded and not holding the brushes tight down against the commutator. Clean and lube them and insure the brushes are not wore too low and the spring assembly holds them down tight. Clean/polish the commutaor also so the brushes make good contact with the shiny copper. 7) The gens 2 field windings must be connected together and continuous between the ARM and FLD posts. The connection where the 2 connect can be broken or one of the windigns may be shorted. (that happens) With the armature removed, insure continuity of BOTH field windings between ARM and FLD posts, and then insure theres no continuity between either and the frame, and if so the field is grounded. This is for a 2 brush generator, if its a 3 brush, the field winding connects from the ARM post,,,,, ,, then goes through one brush and back out the other to the 2 first field, so modify the above test accordingly. If the armature is still in however, the field would always show a short to ground via the armature, thats why the field ground test needs the armature removed. HOWEVER on a 3 brush gen, with the armature removed, you have to make that right connection (which removing armature severed) to perform the field continuity and groundign checks. A good visual interior inspection will show if the wire that connects the 2 fields together is bad or shorted, or if theres a severed wire from either post to the fields or brushes A COMMON PROBLEM. 8) While out, insure the armature windings ARE NOT shorted. A continuity checker between any of the commutator segmentS and thE steel shaft SHOULD SHOW NO CONNECTION. If so, the armature is shorted and bad. SUMMARY. If all the by pass tests (relay and grounded field) and the gen and relay is grounded and theres battery voltage to the relay (non gen side) and she wont charge or fails teh motor test, the commn gen failure causes are worn too low brushes,,,,, ,,,,bad or stuck hold down spring assemblys,,,,, ,,,,, open or grounded filed windings,,,,, ,,,, shorted armatures. NOTE also be sure the posts out the generators case (the ARM and FLD) ARE NOT GROUNDED to the case due to a bad plastic bushing. Be sure and inspect wires from the posts (ARM & FLD) to the fields and brushes and the wire that ties the 2 fields together. They can be bad or shorted to case or broken. Post back and e mail or phone me with any more questions. Good Luck n God Bless John T Nordhoff
