JD 110 Breaker Points and Condenser
corey
08-09-2003 20:08:37
I have a wire coming from the breaker points and was wanting to make sure I'm doing the right thing. I should connect the breaker points wire to the condensor correct? Also, The condensor wire connects to the negative side of the coil, correct?
Bob
08-10-2003 09:14:45
 Re: JD 110 Breaker Points and Condenser in reply to corey, 08-09-2003 20:08:37
Wire from inition switch to (+) side of coil. Condensor and point leads to (-) side of coil.
