44 A axle leaking
david
08-09-2003 18:38:07
i guess i need to remove the wheel to replace a leaking axle retainer?...what can i expect? and whats behind the big round metal disk on the axle?? started leaking pretty bad today the disk came out about 1/4 inch so i tried to knock it back in but it would not go... any help would be appreciated....thank you, dave
Ralph in WI
08-09-2003 22:13:10
 Re: 44 A axle leaking in reply to david, 08-09-2003 18:38:07
I will give a short discussion but you need to go to the left side of this page and under Research and Information, click on:Search This Site. Type in axle seals and search the John Deere disc grp. It will give you a multitude of articles. The outer end of the axle is a felt dust seal not an oil seal. The oil seal is located at the inboard end of the axle. Assumming an A,B,or G, a) drain transmission-diffential oil, b) remove rear differential cover, c) remove axle which will push out the old felt seal and felt seal retainer. d) Siphon oil from the outboard end of the axle housing which I suspect is full, e) replace seal, replace old felt with new dust felts replace bearing if required and install the old steel dust felt retainers. The felt retainers are no longer available. TAKE CARE. Don't be so foolish as to try and follow my sketchy and probably incomplete directions. Research felt seals completely or purchase a Service Manual or both. If the felt retainer has been pushed out I would suspect you have further problems, either the retaining nut is loose or a bearing has disintegrated. Ignoring the problem will only increase the mess and damage.
