720 Diesel won't pull!!
Gilbert
08-09-2003 18:32:39
I have a 1958 720 diesel that seems like the governor won't open up under load. It does not have the deep lugging power of other 720/730's that I have been around. I am open to any suggestions.
Clooney
08-10-2003 18:41:42
 Re: 720 Diesel won't pull!! in reply to Gilbert, 08-09-2003 18:32:39
Gilbert, those diesels use massive amounts of air so make darn sure your air cleaner inner mesh element is clean & not plugged with dirt & crud. Also look into the intake snorkel to see if it is restricted due to a power steering leak & then dirt collecting in there.
~If the intake, & air cleaner are clean & open then you could have anything from plugged fuel filters, to low transfer pump pressure [common problem], to worn injector tips, to weak pumps, to low compression, to a governor problem, to ?
~About all you can do is work your way through all that can effect your power & eliminate all you can..
JIM
08-10-2003 16:40:44
Gilbert, Take a good look at all associate systems before tearing into your govenor. Check your fuel and air systems throughly, if they are with in specification you may have problem with the sliding sleeve or flywieghts in your govenor. With no load the engine speed should climb pretty quickly. If your getting alot of smoke from the exhaust under load it could be an air restriction or a problem with injection pump timing as well as your injectors. Good Luck!
Jim
Chad Sponsel
08-10-2003 14:05:41
Have you replaced the fuel filters? if so Check your injectors. they may need replaced or cleaned.
buickanddeere
08-10-2003 08:22:26
Put here on a M&W dyno. The seat of the pants dyno has suspect accuracy at best.
