214T knotter help needed
Brent in Iowa
08-09-2003 17:34:18
I have a 214T baler and while baling for the neighbor I got a piece of elm bark (huge piece!) in the bale chamber, bent both needles, and messed the timing up bad. Well, I had spare needles on my 14T parts machine so replaced them and re-timed the machine, but now the twine disk on one side starts turning just a hair too soon and doesn't get to grab the twine from the needle before the disk turns too far. My manual says "remove the knotter/twine disk pinion and the knotter worm, and relocate the washers from the top position to the bottom position on the worm shaft." I understand how this will help, but I can't figure out how you get those gears off of the little shaft to get it out to move the washers around. Help please, I have hay on the ground and it is to rain Sunday! Thanks!
p.s. It took me 4 hours to get it timed as some parts in my manual pictures looked/were different than on my baler. My question is: The only way I could get it to time right was when the plunger was fully stroked (compressed) to have the needles to start rising and they come up into plunger slots while it is on it's return stroke. Does this sound right?
randy hall
08-09-2003 21:30:38
 Re: 214T knotter help needed in reply to Brent in Iowa, 08-09-2003 17:34:18
the needles need to be even with the tops of the slots with the pluger from 1/2" to 2 1/4" from the face of the plunger, it is better to be closer to the 2 1/4", as the plunger is advancing not retreating. you still are out of time. if you have to adjust the twine holder discs there is a drive pin in the gears that you have to remove with a punch.
Heat Houser
08-09-2003 19:14:50
Are you sure you have your needles adjusted so they just clear the knotter's twine disks when they are fully in the bale chamber? If you dont, the needle won't lay the twine into the disk and the twine disk will not catch the twine and it will not tie.
Sounds OK on the timing. I always set them to start entering the chamber just as soon as they would clear the plunger face. In other words, they would start to move in but wouldn't make it in until the plunger face was past the needle tips.
